跳转到主内容
The Samsung Gear S3 Frontier (SM-R760 & SM-R765) is a high-end smartwatch designed to reduce the need for your cellphone. Released in November 2016, the device has a 1.3" display, a dual core Exynos processor, and a custom Tizen operating system.
How to replace the front bezel wheel?
My Samsung Gear S3 Frontier front bezel wheel is full of scratches and I would like to know if i can replace it, and how.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
最有帮助的答案
If you can find the replacement wheel. All you have to do is take a very small Jewelers common head, and carefully twist it the wheel will pop off but make sure that you do it in a plastic container upside down. There are four micro ball bearings that will pop out. All you have to do after you take the metal wheel off is take the plastic ring it will look as though it was broken but it is not insert into the bottom of the new wheel put all four ball bearings back in and pop it back on that is all there is to it.
这个答案有帮助吗?
得分 2
添加一条评论
Hi Hugo Trigo,
You are lucky, a tutorial is available on iFixit for your problem.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Guys
So. I got given a S3 classic as a present but I wanted the frontier version with the black face. Dial etc.
Is there a way to change the face from classic to Frontier look. I dont want to just change the bezel. I want to change all the silver.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Also if you need the part number for the replacement bezel you can sometimes find them. I had to buy mine from Switzerland. Part numbers Manufacturer Part Number(s): GH98-40541A; GH96-10729A
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hugo Trigo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 7,876
