跳转到主内容
加入维修社区 - 创建账户
2012 年 3 月发布的一款 95.2 毫米 x 56.5 毫米 x 18.3 毫米的便携式数码相机。
file error message pop up
Why does a file error message pop up when looking through pictures I have taken instead of a picture that I took, but is no longer on camera? instead it says file error with a triangle.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@froggman from the manual:
The following issue can cause a File Error message:
  • The picture file is corrupted
  • The picture was taken with a different manufacturer's camerahe memory card inside your camera is not formatted
  • The memory card in the camera is not compatible or defective and needs to be repalced.
I'd start with formatting the card and see if that works. If not replace it with a new one. you can get the user manual from here which tells you how to format the card etc.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin Hoelscher 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 36
总计 1,186
