跳转到主内容
加入维修社区 - 创建账户
由索尼(Sony)生产的 MDR-ZX100 ZX 系列立体声耳机。
Left speaker is not working
My Headphones Sony-Mdr zx-100.
Left speaker is not working. I opened it wires are pretty fine. but,Speaker is not working. I checked the speaker poles(+ve &-ve) with multimeter,there is no continuity in poles. I think the speaker winding is cut off. Can anyone fix this, please help!
Here is link: https://drive.google.com/folderview?id=0...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
@ramukris how did you test your speaker? What settings did you use? Where did you check?
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
@ramukris you need to check your wires with a multimeter in ohm settings. Then touch the contact at the connector that you plug in with one probe and the other probe on your speaker. If the wires are okay then your needle will move. If the needle does not move you have either a loose wire on the connector or a broken wire. It is uncommon for the windings to shorten out in the speaker itself. Polarity is not important while checking for continuity.
这个答案有帮助吗?
得分 2
1条评论:
what about the right speaker, I accidently dropped my headphones and the right speaker came off but the wire is still attached what should I do?
由完成的 分享
添加一条评论
添加你的答案
Ramu Kris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 914
