跳转到主内容
加入维修社区 - 创建账户
这款 LG Android 设备发布于 2015 年 10 月。用于创建这些指南的设备型号为 LG-VS990。
My phone has a bootloop problem
My phone has a bootloop problem and i tried to repair myself. The repiar was successfull but after two of working, the issue started again.. so i repaired it agian and aftr the cleaning the dust inside my phone, i small chip was hanging to the motherboard.. Well, I know i f**d up, now i want the original LG Motherboard for LG V10 at&t.. Where can i buy the replacement?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
i checked that before,but i need the original motherboard..not the replicas
由完成的 分享
Fixed wife's V10 after it constantly rebooted. I work for CameraSecurityReviews.com in Indiana as a repair technician servicing audio and video equipment like this http://camerasecurityreviews.com/4-chann... . The root cause of this reboot issue, and sometimes overheat issue found in G4,G5 and V10...is a ball-array mounted IC on the main PCB on the screen side of the board. Its a larger IC without the interference shield over it.
The fix involves heating the IC and PCB with hot air and allowing the solder underneath the re-flow and make a connection again. Don't melt any plastic connectors. Also take out any SD card and the SIM card so they won't melt! Hope this helps someone.
由完成的 分享
I baked my motherboard. Worked like a charm. Using it for more than a daynow with no issues.
由完成的 分享
添加一条评论
1个答案
已选择的解决方案
Hi!
You could try hereor here.
这个答案有帮助吗?
得分 5
3条评论:
@oscarsp @yvaneck jkingsnorth sorry but no SPAM here. Just a couple of benign links to a replacement board.
由完成的 分享
Thanks for the warning @oldturkey03 , but I vote as not spam. The links help to solve the problem and I know that @alexniculescu is a good assistant does not send spam. I apologize if I made a mistake marking it.
由完成的 分享
@oscarsp it's all good. Not a warning just making sure helpful answers are not being misunderstood :-) No apologies necessary
由完成的 分享
添加一条评论
添加你的答案
Anche Karthikesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 12,620
