跳转到主内容
What can I upgrade to make this laptop faster?
What are possible upgrades to make my Laptop work a whole lot better? Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Ok. Yes, an SSD can greatly improve the speed of your system. RAM can too. But everything in moderation.
So here are the doctors orders:
  • If you need space but speed, I recommend you remove your optical drive, put you old HDD in there and put an SSD in the HDD's place.
  • If all you need is speed, simply replace the HDD with an SSD.
  • If you don't want to sacrifice your optical drive, but need plenty of space, you can either get an SSHD (a small amount of SSD combined with a HDD) or just a large but expensive SSD.
Got a that? Good. Now onto the RAM.
  • Most people don't use more than 8GB of RAM. If your laptop doesn't already have this, this can also greatly help.
  • If your computer has a single 4GB stick, get another 4GB stick to compliment this. If it has any other size less then 8GB replace it with a single 8GB stick.
  • If you really need 16GB, get two eight gigabyte sticks.
If you upgrade to an SSD or SSHD, you'll have to re-install Windows. Use this link to make a bootable thumb drive: https://support.microsoft.com/en-us/help...
For all your needs, Dell provides repair manuals. I got the one you need right here:
Inspiron 15 3000 Service Manual
Hope this helps! If you confused about all this, just tell me how much storage you need and what you'll be doing. I will also recommend parts once you've made a decision.
这个答案有帮助吗?
得分 4
4条评论:
Thank you very much for that. I'll rate but don't know how. Tell me how for I to rate you
完成的
@reaperxcelerate, you already did by accepting my answer and upvoting it. Thank you!
完成的
Any idea of the current configuration of ram? Is there only one slot? And there is one 4gb ram in there. Or is there 2 slots with one 4 gb ram that I can either add one 4 gb ram to make it a total of 8 ram or add 8 ram to a total of 12 gb?
完成的
Hi @ fardi yeung,
According to the specifications the laptop supports up to 16GB DDR4 2133 RAM over 2 SODIMM slots using either 2GB, 4GB or 8GB modules. See p.13-14
So you can have 12Gb made up of 4 + 8. (ensure that they are of the same speed etc)
完成的
添加一条评论
Upgrade the hard drive to SSD, that is the best upgrade you can make.
这个答案有帮助吗?
得分 2
3条评论:
What else can I do? I know I'm able to upgrade the ram to 16GB. What about the graphics card? CPU? Processor?
完成的
Ram and SSD Upgrades are the only replaceable parts on this machine. Most laptops have the GPU and CPU Soldered to the Mother Board
完成的
That's it? Nothing else?
完成的
添加一条评论
添加你的答案
Ryan Montesino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 5,134
