跳转到主内容
加入维修社区 - 创建账户
这款平板电脑由华硕(Asus)于 2013 年 7 月发布。其型号也称为 ME173X。该平板电脑配备 7 英寸显示屏、microSD 卡槽、MicroUSB 接口和耳机插孔。
Touch screen partially works
Touch screen has area where It doesn't work so I disconnect and reconnect more times the two flat ribbon cables which link touch screen to board but nothing!
Suggestions please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@rickyleroy anytime you have part of a touchscreen that is not working, you most likely have a failed digitizer. Replacing it will fix your issue.
这个答案有帮助吗?
得分 1
3条评论:
If I work with virtual keyboard and I push down specific key, character is not lightened and no symbol is written while if I press it with more pressure another near character is typed.
I avoid this behaviour rotating tablet of 90 degree.
What other test can I do?
由完成的
Where can find guide to replace touch screen for me173x?
由完成的
I replaced touch screen. Now I noted in landscape mode it works fine while in portrait (vertical) mode, with Asus text in top area, the last bottom strip doesn't work where there the 5 five bottoms. If I rotate device of 180 degree the bottoms works so I suspect specific area has issue. What can I do?
由完成的
添加一条评论
添加你的答案
Riccardo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 37
总计 733
