iPhone does not recognize any Sim
Hello,
My iPhone does not recognize any Sim.
What part do I need to replace / fix?
Thanks (
if this is a phone that is new to you- I would check the imei to make sure it is not listed as lost/stolen
clean the sim card
check sim tray for bent/dirty pins.
the paper under sim tray is a great idea..
这个答案有帮助吗?
Well... Try to put a paper or something thin (~1mm) between the tray and the SIM then put it on the phone.
I can't guarantee you that this will work but why not trying?
这个答案有帮助吗?
Please check if your iPhone have carrier lock or not ? If it is locked with any carrier, that sim only works in your iPhone . If you want to use it with other networks, you need to unlock it from the locked network . For that, you can get unlocking servcie from your service provider or from any of the online vendors like Prounlocking.com to unlock it . Once, you have removed network restriction from your iPhone, you can use it with any other GSM carriers internationally .After that, it won't accept/not recognize any sim card, it may be hardware problem .
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,558
