跳转到主内容
加入维修社区 - 创建账户
iRobot Roomba 770 是一款无线自主扫地机器人,无需人工干预即可清洁地面。
Blue light flashing on robot
There is a blue light flashing on the machine and it is making a thumping sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
My blue flashing light looks like a magnifying glass, what is that for.
由完成的
I have a flashing blue light but the indicator looks like a small circle with a few emitting beams, also the side brush is not moving at all.
由完成的
添加一条评论
3个答案
最有帮助的答案
@baldly Roomba 700 and 800: When in Dirt Detect mode, the blue Dirt Detect indicator will flash. You did not tell us which light. The dirt detect is the magnifying light. Make sure that you check the brushes and clean them well. If there is debris stuck on those they may trigger the dirt-detector sensor and you get your blue light flashing.
这个答案有帮助吗?
得分 6
2条评论:
I keep my roomba pretty clean. I cleaned thoroughly and it worked for a few minutes. Then it went back to blue light and thumping noise. Any more suggestions?
由完成的
I have exactly the same problem
由完成的
添加一条评论
I had a blue star flashing and a thumping sound. I have the 770 model, so I went to the Roomba site and found this video: https://homesupport.irobot.com/app/answe...
It was simply a matter of cleaning the front wheel (I did not know it came out to clean it) and cleaning the brush and roller (I actually replaced them since I had spare parts on hand).
这个答案有帮助吗?
得分 3
2条评论:
Blue star flashing after replacing filter roller and cleaner? what does that mean it's not the magnifier it's just a blue star I've never seen it before?
由完成的
bingo! I've had this one for EVER and it has never done the bumpity thump blue star flashing before. I always pull the front wheel out and clean but have never pulled the plastic insert it slides into out. I had a big wad of fuzz under it. cleaned it out and VOILÀ, back in biz.
THANK YOU
由完成的
添加一条评论
Blue star like light is indicating problem with brush movement.
I found dirt under the silicon cover that prevent the brushes from turning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack Luhring 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 48
总计 46,432
