跳转到主内容
Repair and disassembly guides for Toshiba DVD players.
Plays way too loud
Playback volume has gone wrong, level 1 is deafening
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@alholroyd what exact model is this? Is the volume still adjustable or does it just play loud without being adjustable?
完成的
添加一条评论
1个答案
If you go from the DVD player into another piece of equipment, like a stereo tuner or an amplifier, make sure the volume on that second piece of equipment is volume low. Without knowing your setup, it sounds like you might be sending a low signal into something else that is turned all the way up.
It's easy to forget about the amp part of it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alastair Holroyd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 146
