跳转到主内容
加入维修社区 - 创建账户
由索尼(Sony)生产的 MDR-ZX100 ZX 系列立体声耳机。
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide 修理 Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm 插头 to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Sony MDR-ZX100 维修指南 and measure continuity with a multimeter from the connector to the drivers.
Skullcandy SCS-SCBP SKULLCRUSHERS图片
指南
难度:
中等
45 minutes - 1 hour
Sony MDR-ZX100图片
指南
Sony MDR-ZX100 维修指南
难度:
中等
15 - 30 minutes
这个答案有帮助吗?
得分 1
添加一条评论
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nitheesh k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 366
