跳转到主内容
加入维修社区 - 创建账户
这是 Samsung Galaxy J7 的设备页面。该设备出厂预装 Android OS v5.1 操作系统。
Flickering when low light
How to solve plssss my j7 flickers when on low light how to fix help me pls should i replace the lcd or their is other things to replaced or it just needs something to be solved ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
my samsung J7 camera light cannot go off. steady ON
由完成的
添加一条评论
2个答案
已选择的解决方案
@kobexkyrie seems to be a very common issues with this model. It is the backlight that is flickering at higher/lower power demands. Could be filter or power IC as well as the Amoled. Take a look at Flickering screen on low back light and see if some off that will work for you.
这个答案有帮助吗?
得分 1
4条评论:
Sir what do you mean of off ?I just updated the model than it started flickering
由完成的
@kobexkyrie of off ? I was stating that this seems to be a common issue with this model phone. Check the answers on the link in my answer to you. Click on the light blue writing :-)
由完成的
Thanks for the help it helps me a lot to save
由完成的
Sir unluckily it didnt work even the screen filter doesnt work also what should i do
由完成的
添加一条评论
I replaced with new battery and problem went away.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fixie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 17
All Time: 17,545
