跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Wifi signal very low after repair
Cut a long story short, I have become slightly addicted to repairing my own phone after apple keep trying to rob me in full daylight. The screen cracked a while back and I stripped it, replaced it and put it back together, everything went great and from that moment on, I failed to understand how they could quote me like £130 to fix it?
So anyway, recently it stopped charging, worked until the battery went dead, I again visited apple and they diagnosed water damage to logic board, £140 (How so when it worked fine until battery died) so I narrowed it down myself and discovered all that needed replacing was the dock connector, done, back in great....however the WIFI signal is rubbish, I've put connector 6 back on right but it's just not what it used to be. I can stand literally 2 meters away from my router and have 2 bars?
Has anyone got any idea what's happening....
NB: Sorry, I didn't exactly keep it as short as I'd planned.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I've done all of that up until the heat gun part, although it may have been tried and tested it wont be happening to mine, not while I own it anyway.
The resetting of the network proved unsuccessful so might be another trip to ebay for a wifi antenna....oh well.
完成的
添加一条评论
5个答案
已选择的解决方案
take a look at this answer before you visit ebay. may save some pennies iPhone 3G WiFi chip failure after 18 months
这个答案有帮助吗?
得分 2
添加一条评论
1. Tap Settings
2. Tap General
3. Tap Reset
4. Tap Reset Network Settings
This will cause your iPhone to restart, and will delete any stored Wi-Fi passwords as well as DNS settings and more. It may, however, restore your ability to join a stubborn wireless network. I also attach this interesting link just in case....its about the repair of the WIFI and reflowing the logic board.http://www.iphonetiquicia.com/iphone-wif... let us know what works for you and how it is progressing....good luck
这个答案有帮助吗?
得分 1
添加一条评论
Did not work for me, Signals appear to be very weak
这个答案有帮助吗?
得分 0
添加一条评论
you can get the 3G antenna signal coil on the back of the logicboard here
这个答案有帮助吗?
得分 0
添加一条评论
Bumping an old post, but in my experience a weak wifi signal (as opposed to no wifi) is often caused by damaged cable for connector 6. If you did another repair then you may have stressed the cable a bit and broken a connection. Here are the instructions for this repair-
iPhone 3G GPS Antenna Replacement
The iFixit Guide refers to this as the GPS atenna module, but pretty sure it is for both GPS and wifi.
Its one of the more involved iPhone repairs because you have to first remove the large cable assembly that controls the volume, power, etc. Getting that back on is sort of a pain, but just be patient and you should be fine. Just look at the pictures for reference of the original arrangement.
IFixit doesn't seem to sell this part anymore (or else I would post that link), but it is available on EBay for pretty cheap. Well worth the benefit of good wifi again. Another possibility is that you damaged the connector on the motherboard itself, but that is generally less likely unless you really applied too much force.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wayne Rees 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 16,435
