跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
iPhone 3G WiFi chip failure after 18 months
WiFi stopped working three days ago after 18 months of use. Verified no router or software problems. Apple in-store "Genius" suggested to upgrade to a new phone. Online Apple Tech support indicated WiFi chip has failed and is not repairable after various tests.
Anyone know if it is possible to replace such a chip on the [I presume] motherboard? And who may be doing such repairs.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
replacing the logic board is a very pricey issue.
afaik - reworking the wifi part should be possible - but not for everybody - maybe you should search a little bit for companies that do those kind of repair for living - i think that a repar is cheaper than an new logicboard
这个答案有帮助吗?
得分 2
添加一条评论
well I'm having same problem here:
WIFI chip died without any inappropriate usage.
Basically I know the chip is hard to get and hard to weld according to my geek friends
so I thought to myself:
if it's hard to weld, that means it's welded well
and if it's welded well, all we need to make the link between logic board and the chip back online is to add something on the back on the chip, so the chip can gain some physical pressure and then the link will be assured.
And THAT WORKED!!!
all I did was add on a thin plastic piece on the back on the chip (between the chip and the back shell to be exactly)
Hope this can solve your problem:)
Solution from China (by Lupin3rd)
这个答案有帮助吗?
得分 2
1条评论:
interesting solution! will try it out...
完成的
添加一条评论
添加你的答案
geckopelli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 16,120
