philips pd9030/05 no power at all not charging or turning on
portable dvd is not charging or turning on with a 12v car power lead or a 9v house power pack
red charge light flicks on then off
I would start off by replacing the battery. Here's how:
这个答案有帮助吗?
roblouiscoleman bad battery is a possibility but you definitely want to check your DC in jack to make sure that it is properly connected to the board. For that you will have to disassemble your DVD player. This document should come in handy for that Philips PD9030_05 SM If the DC jack is properly mounted and you measured the input from the power adapter with a voltmeter, you could always check the fuse F1 as well as the caps, and see if you have power on the circuitry.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 907
