跳转到主内容
加入维修社区 - 创建账户
LN-T5265F 是一款来自三星的 52 英寸高清电视。
Horizonral lines on screen
Have four static horizontal lines on screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bsearle that is usually caused by a bad panel. You would need to remove the back of the TV set and try to get to the ribbon cables that enter the panel. Then put some pressure on those flat ribbon cable near where the lines appear. If this changes the lines, you will have a TAB error. No easy fix with that. Sometimes applying some strong tape over the ribbon cables to exert extra pressure may help for a while. It will help if you can post some images of what your screen shows, as well as what your set looks like with the rear cover removed, we might be able to assist you further. Use this guide for that so we can see what you see.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Barb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 381
