跳转到主内容
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
20 个问题 查看全部
J5 Prime Phone will not turn on
So I've had a Samsung J5 Prime for just over 5 months now, and this is the first time it's ever acted up. I didn't charge it over the night, (I forgot) but charged it when i woke up and it was around 60% before I went to school. After about 4 hours of working fine, I went to check the time and my phone wouldn't turn on at all. Held down the power button etc and naturally assumed it had run out of battery. I remember it had about 40% charge left which I thought was a little strange, but I came home and plugged it in.
I've left it charging for about an hour and a half now, but nothing has happened, no red light, no response.
Yes, I checked if the charger was turned on.
I've tried holding down the power button while it's charging
I've tried switching power plugs and chargers
No idea what to do......
Also, the back cover doesn't come off so i cant take out the battery etc.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 33
31条评论
awesome!!!!!!!!!!!
完成的
My phone doesn't turn on but the battery/charging indicator is red I've put it on charge for hours now.I've tried soft reboot solution but didn't work.help pls.
完成的
I've had this problem just a few moments ago. I got the correct answer from one of the comments. Thank you very much for posting the answer.
完成的
SamSuung J5 Prime is a working time bomb.... Another error!!! While watching a movie, my J5 Prime makes a sound like a lose fan very loud and it hooks and the phone stopped working this is the 2nd time in 2days...
完成的
Hey my Samsung turns on but it wont show the menu .....it turns on but stucks at the sign SAMSUNG
完成的
显示更多的26条评论
添加一条评论
2个答案
已选择的解决方案
Hi Liz,
You're probably solved this by now - but I just had the same issue. Nothing else I tried worked before this:
I pressed Volume Down + Home Button + Power Button for a few seconds.
After a few seconds I got a turquise screen warning me about a custom OS install.
I cancelled that with a Volume Down press and then my phone booted normally.
Got the idea from here.
Hope that helps Liz (and you future Internet person),
Z:D
这个答案有帮助吗?
得分 184
99条评论:
Thanks so much for helping out!
You're right - I did end up solving it on my own but thank you anyways
Holding down the home and power button at the same time works as well, (it's called a soft reboot, same as taking battery out on another samsung) that's how mine turned on.
完成的
this is awesome!! thanks for the great tip! i thought i had to go down to the customer service centre to get the set replaced.
完成的
my screen is blinking and thats why
i cant rebbot my phone
完成的
Thank you so much. it helped me a lot after i faced this problem for the first time..:)
完成的
THANKS a lot dear it works no need to go to repair shop..
完成的
显示更多的94条评论
添加一条评论
Charge with original samsung power addapter and cable.
这个答案有帮助吗?
得分 2
1条评论:
omg thank you so much!
完成的
添加一条评论
添加你的答案
Liz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 58
总计 120,704
