跳转到主内容
加入维修社区 - 创建账户
Nikon N80(也称为 F80)是一款 35mm 单反相机。它于 2000 年 1 月发布,型号为 1776。
Is it a brick?
Hello!
I just bought a used Nikon N80. It seemed to be in perfect condition, but I took it home and discovered a focusing problem.
The image in the view finder is dim. And when I try to focus, the lens goes in all the way and back out to infinity without finding a focus point.
I tried a few lenses with the same result.
I checked the sensor at the bottom of the chamber, and it's clean.
Like I said, the camera seems to be in great condition otherwise.
What do you think? Is this a brick, or can I fix it?
I should also mention that I bought the camera with the lens improperly attached. I had to carefully cut a tiny piece of plastic off the lens mount to get it off.
Fortunately I paid only $20 for it, plus new batteries.
Thanks for any input on this!
Eric
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Eric Zulaski I wonder if you have trouble with the AF unit or if an adjustment would work. Since you are only in for $20 it maybe worth your while to get the repair manual from this page (under "Document") and go through the adjustment routines etc.
这个答案有帮助吗?
得分 3
3条评论:
Thanks for the tip. I will certainly give it a try.
由完成的 分享
I had been on the guide page, but I didn't notice the repair manual tucked in there.
由完成的 分享
It's a present added after you asked the question
由完成的 分享
添加一条评论
添加你的答案
Eric Zulaski 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 32
总计 613
