跳转到主内容
加入维修社区 - 创建账户
Toro 公司生产的手推式割草机的维修信息与支持。
Self propel not engaging
Tried tightening cable down toward the engine as instructed. Tried adjusting it a little bit either way too.
Help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
paulagarey what exact model is your mower?
由完成的
NNothing has resolved the problem but at least I can't rule out some things...Thanks for your help..
由完成的
添加一条评论
2个答案
已选择的解决方案
paulagarey, The belt may have fell off or may have broke, engagement lever may be loose or tensioner pulley may have fallen off/loose, gear damage in gear box, wheel gear teeth or drive gear damaged/worn, loose/bad input shaft,cable stretched/broke/disengaged. Some of these mower's carried a 4 year warranty I believe, perhaps see if yours is still warrantied and have repaired under warranty if it is. See links below for checking/diagnosing self propelled mowers. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=3G0a11Vt...
https://www.youtube.com/watch?v=y3ej_jG6...
https://www.youtube.com/watch?v=eSaNVZaU...
https://www.youtube.com/watch?v=_sWrC7Pb...
https://www.youtube.com/watch?v=cqmaQ7Lx...
这个答案有帮助吗?
得分 5
2条评论:
Nothing has solved the problem. Seems as tho everything else is ok. Thanks for your help tho
由完成的
paulagarey, Thanks for replying back, some of these mower's carried a 4 year warranty I believe, perhaps see if yours is still warrantied and have repaired under warranty if it is.
由完成的
添加一条评论
The most likely problem is a broken drive belt. Depending on your model, this may be either on top of the deck or underneath. If that's not the problem, it could be broken drive shafts or stripped gears in the transmission. You'll have to do a bit more troubleshooting...
这个答案有帮助吗?
得分 0
1条评论:
Mine was as simple as rolling the lawnmower on its side (air filter side always faces up), slightly pulling the drive belt protective cowling away from the blade shaft, and pulling the belt back over the groove on the blade shaft. It’ll still feel loose, but go ahead and give it a try. Whatever you do, locate your drive belt first. One end in the motor, the other around the blade shaft. Blade shaft.
由完成的
添加一条评论
添加你的答案
paulagarey 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 41
过去 30 天: 219
总计 43,994
