跳转到主内容
加入维修社区 - 创建账户
PC -ER code on fridge
I went to get ice from my ice maker and water came out instead. Then the Samsung fridge made noise and code PC-Er came on. I tried pressing power fridge & power freezer for 8 seconds which cleared it but once I tried to get ice again same thing happened.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Does your ice maker make ice?
由完成的 分享
@dede14 what model is your fridge?
由完成的 分享
Mine done same thing , I pressed ice button an PC er came up on display ! Previous evening I started the ice again as it was off as no need for ice during winter months really ! Then water started coming out of top of ice maker part ! Any ideas if the code is related to error on ice maker ?
由完成的 分享
Had the PC - C error on my Samsung RS62K62B7SL/SA after a very short power outage. To clear it I had to run an extension cord and power it from another outlet, then plug it back into the one in the fridge alcove.
由完成的 分享
I have a model # rs265tdrs when you switch from ice to water I get pc er code flashing. Help!
由完成的 分享
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
@dede14 , Dede ,With out knowing your model # this is the Info.found, from link below. Display Panel Is Showing PC-ER:
If the display panel shows PC-ER, make sure the wire harness under the top left door hinge is properly connected. Unplug the refrigerator and remove the top left hinge cover. Unhook the wire harness and reconnect it. Plug the fridge back in and if the fault code goes away then the issue is fixed. See illustrations below. The link below also has a lot of good info. for you to check out, diagnostic checks, etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://removeandreplace.com/2015/08/10/s...
这个答案有帮助吗?
得分 4
5条评论:
Did this several time but always came back a day or two later
mdr438@att.net
由完成的 分享
rapmk, if you have a question, POST as a question and not a comment and include all the details of problem/make/model#?etc., so all ifixit volunteers can see and possibly give a solution.
由完成的 分享
good morning, the pc er code is still there
由完成的 分享
I have had same problem but Samsung don't no what it is .all the same old answers but no help don't no how many times. Done this can someone help
由完成的 分享
Samsung fridge has same issue. PC ER on display.
model RF 263BEAESR
由完成的 分享
添加一条评论
添加你的答案
Dede 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 46
过去 30 天: 201
总计 53,253
