跳转到主内容
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Will not turn on, no image on the screen.
will turn on, theres a green light indicator but no image loading on the screen, tried removng batterry and resetting by holding power button but wont do, when try to remove and re insert battery, green light indicator automaticaly turn on w/o sliding the power buttton on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
franklyn72001, did you get it fixed?
完成的
添加一条评论
2个答案
最有帮助的答案
try to turn your psp on using charger and if you can connect it to a tv and see if the display turns on if it does then take it off display and if its still black screen then that means you have a backlight fuse problem.
这个答案有帮助吗?
得分 1
添加一条评论
buy a new battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
franklyn72001 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 5,260
