跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Absolutely no sound from Ipad 2
After battery, digitizer, and widi antenna replacement sound no longer works from headphone jack or speakers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did verify conn before putting digitizer on
完成的
添加一条评论
1个答案
已选择的解决方案
Try cleaning the charging port, sometimes it gets oxidized and gives such fault. If you can replace it with a working one it would be even better.
这个答案有帮助吗?
得分 1
3条评论:
I will try a new chare port
完成的
Unfortunately that did not seem to fix the issue. I ordered new speakers and headphone jack assembly
完成的
I'm a bit skeptical that will fix the issue, but there isn't much else left apart from a problem on the board itself. Hope you will succeed.
完成的
添加一条评论
添加你的答案
Bradley Crawford 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 825
