How do I get a stuck BB out?
If a bb is stuck in the gun how do i get it out
A'Leah Key , Get metal/brass rod slightly smaller than the bore diameter less then .177"/4.5mm, approx. rod size 5/32"or smaller should work fine. Make sure all other BB's are out of the reservoir and leave the door open, put a couple drops of oil in barrel, slide rod in the barrel from the muzzle until it hits the over sized BB and then tap it lightly with a hammer. The rods can be found at hardware/metal supply stores. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
An old stainless steel radio antenna works too!
is there a way I can send it cause I can't fix it when I took the screw out the trigger went upside it won't come back down I could see that the screw I took out doesn't lineup even when I took it out the screw hole is to one side
i cant get the trigger back down
i recently had same problem with red ryder bb gun . I was able to remove the plastic front sight by bumping the back of the sight. Then with needle nose pliers twisting and gently pulling inner barrel out. I found a stiff wire about the right size and attempting tapping the obstacle out, but didnt move much. luckily I was able to drill the object out because it was near the input end of the barrel. I believe it was a misshaped bb or two. I put the barrel back in by pushing it with a little force and twisting it. then simply snaped the plastic sight back into place. The sight looks like it has a screw but it is only plastic cast. The outer barrel is slotted for it to slip into.
这个答案有帮助吗?
usually a small dowel the size of the barrel will work poke it in the front end to the back
这个答案有帮助吗?
If it is in the barrel of the weapon then using a metal thin line or something small but agile that can fit through the barrel to push the BB back into the loading chamber(or reverse) should work. Make sure the magazine is out so that the BB just falls right out. If it gets stuck at the back of the barrel and is unable to fit through the loading chambers transfer hole I would then recommend either deconstructing the gun so that you can get at the BB or bring it so a store that can repair it. If the BB is stuck in the magazine because you loaded it improperly, your best bet is take apart the magazine to get at the misplaced BBs unless the magazine in this case has a released lever so that the BBs can simply drop out of the magazine.
这个答案有帮助吗?
guy so i have a D93 uzi and whe i try to shoot it nun comes out andthe batter starts to get hot too can you guys help me fix it
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 54
过去 30 天: 256
总计 40,581
11条评论
Where is it stuck?
由 mayer 完成的
I have it stuck in the clip loaded it wrong
由 Earl 完成的
Hey does anyone know how I can get my mag out of my airsoft pistol it is stuck beacause of a bb witch is blocking the mag plz help!
由 Chumpa 完成的
Lots of force, the mag is made out of steel, the BB is probably copper or something soft, the BB should give first, dont be shy.
由 Duane Donaldson 完成的
I have a MK-177 BB gun with a loose bb that moves around whenever I move the gun and at one point the inside of the barrel feel out and I put it back in dont know if that has anything to do with it but other then that does anyone have any idea how to get the loose bb out its annoying the &&^& outta me btw lil tipsy when I made this comment sorry if everything doesnt make sense
由 Blazedkitten6969 完成的
显示更多的6条评论
