跳转到主内容
The Red Ryder BB Gun is a BB gun made by Daisy Outdoor Products and introduced in 1938 that resembles the Winchester rifle of Western movies.
22 个问题 查看全部
How do I get a stuck BB out?
If a bb is stuck in the gun how do i get it out
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
11条评论
Where is it stuck?
完成的
I have it stuck in the clip loaded it wrong
完成的
Hey does anyone know how I can get my mag out of my airsoft pistol it is stuck beacause of a bb witch is blocking the mag plz help!
完成的
Lots of force, the mag is made out of steel, the BB is probably copper or something soft, the BB should give first, dont be shy.
完成的
I have a MK-177 BB gun with a loose bb that moves around whenever I move the gun and at one point the inside of the barrel feel out and I put it back in dont know if that has anything to do with it but other then that does anyone have any idea how to get the loose bb out its annoying the &&^& outta me btw lil tipsy when I made this comment sorry if everything doesnt make sense
完成的
显示更多的6条评论
添加一条评论
7个答案
已选择的解决方案
A'Leah Key , Get metal/brass rod slightly smaller than the bore diameter less then .177"/4.5mm, approx. rod size 5/32"or smaller should work fine. Make sure all other BB's are out of the reservoir and leave the door open, put a couple drops of oil in barrel, slide rod in the barrel from the muzzle until it hits the over sized BB and then tap it lightly with a hammer. The rods can be found at hardware/metal supply stores. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 5
1条评论:
An old stainless steel radio antenna works too!
完成的
添加一条评论
i recently had same problem with red ryder bb gun . I was able to remove the plastic front sight by bumping the back of the sight. Then with needle nose pliers twisting and gently pulling inner barrel out. I found a stiff wire about the right size and attempting tapping the obstacle out, but didnt move much. luckily I was able to drill the object out because it was near the input end of the barrel. I believe it was a misshaped bb or two. I put the barrel back in by pushing it with a little force and twisting it. then simply snaped the plastic sight back into place. The sight looks like it has a screw but it is only plastic cast. The outer barrel is slotted for it to slip into.
这个答案有帮助吗?
得分 2
添加一条评论
usually a small dowel the size of the barrel will work poke it in the front end to the back
这个答案有帮助吗?
得分 1
添加一条评论
Use ur hands and get it
这个答案有帮助吗?
得分 1
添加一条评论
If it is in the barrel of the weapon then using a metal thin line or something small but agile that can fit through the barrel to push the BB back into the loading chamber(or reverse) should work. Make sure the magazine is out so that the BB just falls right out. If it gets stuck at the back of the barrel and is unable to fit through the loading chambers transfer hole I would then recommend either deconstructing the gun so that you can get at the BB or bring it so a store that can repair it. If the BB is stuck in the magazine because you loaded it improperly, your best bet is take apart the magazine to get at the misplaced BBs unless the magazine in this case has a released lever so that the BBs can simply drop out of the magazine.
这个答案有帮助吗?
得分 0
添加一条评论
guy so i have a D93 uzi and whe i try to shoot it nun comes out andthe batter starts to get hot too can you guys help me fix it
这个答案有帮助吗?
得分 0
添加一条评论
i have a daisy airsoft bb gun and my mag is stuck and it wont come out
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
A'Leah Key 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 285
总计 39,196
