跳转到主内容
加入维修社区 - 创建账户
Asus ZenPad S8 是 Asus 推出的一款 8 英寸 Android 平板电脑。于 2015 年 6 月发布。型号:Z580CA。
Water damage please help
My two year old pee'd on it is there any chance i could repair it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@cainz, Cainz , Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the tablet from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the tablet to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the tablet and see if further damage has to be addressed. Good luck.
ASUS ZenPad S8 拆解
Electronics Water Damage
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cainz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 518
