跳转到主内容
加入维修社区 - 创建账户
Nissan Altima 是一款由日产制造的中型汽车,可以说它是 1957 年开始的 Nissan Bluebird 系列的延续。
Replacement headlight fuse location
It would appear that the driver's side headlight fuse is blown. The problem is that neither fuse box has an indication as to what fuse belongs to the headlights.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Where is the fuse located inside the car or under the hood
由完成的
Fuses are good, what else could prevent hi & lo headlights from lighting up?
mpgrote@comcast.net
由完成的
Where are the headlight fuses??
由完成的
添加一条评论
2个答案
已选择的解决方案
Okay just checked in the service manual and it looks like the following: 30 headlamp L low, 20 headlamp R low, 28 headlamp L high, 27 headlamp R high, hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
how does this help me find the fuse and or fuse box
这个答案有帮助吗?
得分 0
2条评论:
vrok73 it does not. It was not meant to help you. It was meant to help the OP. If you need some help with your vehice, just use this link and let us know what you need.
由完成的
The fuses are in the Power Distribution Module located in a black box behind the fuse box on passenger side of RHD vehicle. Has four clips and very hard to get off! Has all the fuses that are not mentioned in the other three fuse boxes.
由完成的
添加一条评论
添加你的答案
Frank 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 33,793
