跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Multiple ISSUES READ (No Power, Blank Screen, Start up Sound)
I have a lot of Samsung Galaxy S6 that have issues:
Phone shows red dot and blank screen, no sound, no start up etc.
Phone Blank screen, sounds,etc.
Phone shows battery symbol, won't charge.
Update (03/04/2017)
I appreciate your comment. I would like to ask you about this specific one. The screen on the device was dead or not working properly, so I switched it to a working on and it just shows the battery symbol charging with lightning bolt and never turns off of that screen. Even when you unplug the battery and just connect it, still shows the same thing. I've left it on the charger for about 15 minutes and same outcome. I'm new to Samsung Devices so any help or guidance would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
@stengfix are you saying you have multiple phones with those issues or one phone with all those issues?
完成的
A lot of them with those issues 100-150 qty.
完成的
添加一条评论
3个答案
已选择的解决方案
If we are dealing with multiple phones the one with the blank screen but with sound is a bad LCD this guild will help with that
三星盖乐世S6的屏幕更换
and your replacement screen
Galaxy S6 Screen
The one with the red dot may be just a bad connection to the LCD try reseating the contacts. clean both sides of the connection with 90+% IP alcohol and a soft toothbrush . Check for bent pins or missing pins.
The issue of not charging could be either a bad battery or the charge port . to replace the charge port follow this guide
更换三星盖乐世S6的子板
and a replacement port
Galaxy S6 Charge Port
or battery
Galaxy S6 Battery
Hope this helps
Galaxy S6 Screen图片
产品
Galaxy S6 Screen
$92.99
Galaxy S6 Battery图片
产品
Galaxy S6 Battery
$26.99
Galaxy S6 Charge Port图片
产品
Samsung Galaxy S6 显示屏图片
指南
三星盖乐世S6的屏幕更换
难度:
困难
2 - 3 hours
Samsung Galaxy S6 子板图片
指南
更换三星盖乐世S6的子板
难度:
困难
45 minutes - 2 hours
这个答案有帮助吗?
得分 3
添加一条评论
Could be all just bad LCDs.
If it boots up with no display then it's probably the LCD as they can just stop working after the phone gets dropped right after.
这个答案有帮助吗?
得分 2
添加一条评论
@stengfix That is a tall order. I'd suggest that you start off with one or two and ask questions specific to that one. If you want to get trouble shooting advice for all of them at the same time, this may not be the right forum for you. You do want to consider getting a good service manual so that you can do the trouble shooting.
Update (03/04/2017)
@stengfix for the one you changed the display, which is working, but is stuck at the battery charging symbol, I'd suggest a new battery. If a new battery is not working, troubleshoot from there. You have to have a known-good starting point. Otherwise you are chasing your tail and potential go down a rabbit hole. Here is a start for further troubleshooting should it become necessary after changing the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 121
