简介
根据本指南以更换三星盖乐世S6显示屏。该组件由一个AMOLED和触摸面板构成。组件是封装的,务必同时更换。该步骤对修理屏幕破损或触摸屏反应迟缓的问题很有帮助。
本指南仅涉及到拆卸后部玻璃面板,金属中框,逻辑主板和电池都在原位置。注意: 一些更换的屏幕已经提前装在中框上了 (又名,chassis),那么这样就需要你把手机内部配件都转移过来,并且装上一个新电池。这样的步骤非常不同,所以确保你在开始本指南之前就有了正确的配件。
如果中框损坏或变弯,那么需要更换它,不然新的屏幕就不能装上了,屏幕的压力将变得压力不均。
拆卸后部玻璃面板需要去除将其固定的粘合剂。参照 [无效指南链接] 以重新组装后部玻璃面板。
从中框拆离屏幕的过程,经常会损坏屏幕,所以如果你要替换屏幕的话再使用本指南。
工具
参考以下步骤的相反顺序重新安装你的设备。若要重新组装后部玻璃面板,参照 更换后部玻璃面板粘合剂的指南
279等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
6条评论
I replaced my screen now my service doesn't work as well as it did before. What could I have missed.?
First thing you want to do is make sure that all the cables and wiring are in place on your device's logic board. I have seen this several times in my cell phone repair history.
If that step does not fix the issues then you want to change refer to the Samsung Support site about No Signal issues.
Latent or low service bars after you remove the mid-frame from outer frame is due to contacts within the outer frame not making the proper contact with the board. You can test service outside the frame which is one to two bars and very difficult to make calls. Once refit to the frame properly the service is boosted. If you are having service issues, its more than likely the frame. Take apart and check the inner frame and reassemble. Check service before you replace the back screws and glass battery door.
at step 18 make sure all of your motherboard components are free, my headphone jack got stuck on the frame and i nearly ripped the whole thing off
Note: a good test for broken OLED is to shine a UV light at it.
Broken units typically do not fluoresce corectly and show red “patches” where water has got in.
If you compare with a known good unit the difference is very obvious.
Note: if someone has changed the glass and used third party LOCA it will light up blue not white!
