跳转到主内容
加入维修社区 - 创建账户
Xperia Z1 Compact 是索尼推出的高端拍照手机。它与 Xperia Z1 型号类似,但体积更小、价格更低。其主要特色是搭载了一枚 2070 万像素的传感器。发布时有白色、黑色、粉色和青柠色可选。 可通过型号(D5503)识别该设备。
Power button not working
Hello!
Customer came in with he's Sony Xperia Z1 Compact where the power button was not working and the volume buttons was barely working. So i told him i will order the flex cable part and get it fixed.
When i opened the phone i first checked if all that was needed was just to attach the plastic bit holding the flex cable into place a litle more. But still didn't work. So i went ahead and changed the flex cable.
After the change, the button still won't work. I checked and double checked my work and all seems normall. I also tried changing the button flex cable again.
Now the phone won't turn on and the buttons are not working.
Most important is to get the phone on without losing any files.
Anyone have any ideas, suggestions or solutions? it would be most greatfull.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@oldturkey03 Thanks for your answer.
I tried and looked at all the steps in your post and all seems well. The phone shows the Sony logo if i put in the charger but getting it to turn on as the power button won't work is not going well.
由完成的 分享
Did you find the root cause?
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
@captaintech I'd start off by using Sony's suggestions.
1.1 Power
1.1.1 Will not power on or will switch
off randomly
Check:
Check whether the phone vibrates by pressing the on/off key.
Action:
1. If activation of the vibrator is detected, refer to section 1.4 ‘Display’.
2. If NO activation of the Vibrator is detected, check that the battery is charging when connected to a charger and do a HW master reset.
Follow 1281-3374 Test Instruction - mechanical chapter 2.3.7 (Charging via USB and Easy Charger), Diagnostic Battery / Charging status.
Check:
Inspect the on/off key.
Action:
Refer to section 1.2.3 ‘On/Off Key’.
Check:
Inspect the BtB connector of the Battery to Main PBA.
Action:
1. If not properly connected – disconnect and reconnect it.
2. If dirty or oxidized – clean the both sides of the BtB connector.
3. If the BtB connector, the Battery FPC or the Battery is damaged – replace the Battery.
4. Replace Main PBA.
1.2.3 On/Off Key
Check:
Inspect the external area of the On/Off Key.
Action:
If dirty – clean it.
Check:
Inspect the BtB connector of FPC Side Key to Main PBA.
Action:
2. If dirty or oxidized – clean it.
3. If the FPC of FPC Side Key is damaged – replace the FPC Side Key
Check:
Inspect the area and position of the FPC Side Key (Power On/Off) (a) and On/Off Key (b).
Action:
1. If dirty – clean them.
2. If the On/Off Key is damaged – replace the Frame Main Assy.
3. If the FPC of FPC Side Key is damaged – replace the FPC Side Key.
You can also check a few other things like this one
R1304 is a 0.01 Ohm +/-1% 200.0 mW Resistor
这个答案有帮助吗?
得分 2
添加一条评论
Open the sim card tray you'll find small red button besides tray press it using pen tip till handset vibrate. Now your phone will be turn on without losing your files.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for your answer. We already tried that and unfortunatly it was not successful.
由完成的 分享
Hi! Great post!
What is the part number of the BtB connector in the Board of Sony Z1 Compact?
由完成的 分享
添加一条评论
添加你的答案
Total Repairs AS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 13,887
