跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Will not restore to factory settings
I got a iPhone 4s from my friend and he told me to fix it but I have tried to put it in recovery mode and DFU mode but both do not work I need help guys I need to know what to do from here...?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Does it say anything when you plug in the Iphone to your computer? and its not the charger cord correct?
Just need more info! Thanks in advance!
这个答案有帮助吗?
得分 1
9条评论:
It says you have to unlock the iPhone before iTunes can sync the phone
完成的
The charger works fine
完成的
and you have trusted the computer? if not, try doing that. and if you did, maybe try disabling the passcode on the iphone under settings and then "Touch id and passcode". then type in your current passcode and disable the "Iphone unlock" option. Good luck!
完成的
Oh sorry , It is disabled now and it says connect to iTunes and my computer is a Mac
完成的
And it has never been synced to the computer before
完成的
显示更多的4条评论
添加一条评论
Put the phone one and confirm if the Home button works. If it doesn't you have to change it.
If the button works then it may be the lightning port - 1st try to clean in inside if still doesn't work - change it.
Let me know how it goes.
这个答案有帮助吗?
得分 0
1条评论:
The home button works and I have cleaned out the port and changed cords and still doesn't work
完成的
添加一条评论
添加你的答案
Ty Roessler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 93
