跳转到主内容
加入维修社区 - 创建账户
通用汽车 (GM) 旗下 Oldsmobile 部门生产的车辆的维修指南和支持。
How to fix window motor
My windows stopped working. Checked the fuses and it is good. What else can it be??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
margaret shaffer , You do not state your year and model, but I will give you some ideas what would cause this power window issue. If vehicle equipped, check position of window lock out switch and swith it position and try. Recheck all fuses under hood and interior with test light or DVOM to ensure all are OK. Faulty pwr win. relay switch out relay with a known working replacement, main window switch/control panel faulty, test for power to the main switch if no power wire could be broke/pinched in the harness between door and frame opening. All power window motors faulty(would be very unusual but could happen). Below are some trouble shooting guide links that may help you diagnose the problem. Good luck.
http://www.agcoauto.com/content/news/p2_...
https://www.youtube.com/watch?v=2tLmH05U...
http://www.aa1car.com/library/power_wind...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
margaret shaffer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 259
