跳转到主内容
加入维修社区 - 创建账户
佳能于 2012 年发布的第三代 5D 单反相机的维修指南与支持。
err 40 at power up
Hi,
my camera 5dmk3 power up correctly but it returns err 40. could it be an issue related to the PCB bottom or the DC-DC PCB, what's your opinion regard it?
I tried to load / access to your canon eos 5d mark 3 parts catalog , but it does not loaded. Is it in progress or is it not available?
Thanks in advance
Giorgio
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Giorgio Ba err40 is most commonly an electrical error. It can be related to the battery (first thing I'd replace) but also with the flex cables going to the DC-Dc board etc. Not sure why the parts catalog does not download for you. Added it on here==>>EOS 5D Mark III Parts Catalog
这个答案有帮助吗?
得分 1
添加一条评论
Hi Giorgio.
Did you find out what was wrong?
Rune
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
Problem- A power malfunction have detected.
DIY- Turn off the camera and after 15-20 seconds power it on.
这个答案有帮助吗?
得分 0
添加一条评论
Was you in wet condition (moisture, raining, etc.) and after that camera´s went to faulty?
这个答案有帮助吗?
得分 0
添加一条评论
The bottom flex cable, between the bottom and main board, if installed backwards, can cause this error. The end with a B on it should be on the bottom board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Giorgio Ba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 23
总计 4,654
