Drain pump access on LG D1454TF?
I have an LG D1454TF and it is giving the OE error code and doesn't drain. I can hear the pump is starting up but it seems slower than normal, possibly something stuck in it slowing it down. What's the easiest way to access the drain pump to inspect it? The maintenance manual is here https://www.manualslib.com/manual/106987... Thanks in advance for any help offered :)
1条评论
Bob Ind , Normally you would shut off power and water to it, unscrew the tip over/mounting screws above the dish washer going into counter top frame remove bottom kick panel to access wiring or plug in(disconnect) and water supply line(remove). Pull dish washer from cavity and turn on its back to access pump to check for clog. Reverse order to install. Good luck.
由 L Pfaff 完成的
