跳转到主内容
Restricted access changed voice service blocked
Phone was working fine and then it stopped being able to make calls. I was able to use the Wi-Fi network and make texts and then soon after I started getting the message restricted access change voice service blocked I talked to Verizon store and they were unable to diagnose what the problem was
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
11个答案
最有帮助的答案
Here is an article on it. In short, its a feature not a bug.
http://valuestuffz.blogspot.com/2016/05/...
这个答案有帮助吗?
得分 3
添加一条评论
I don't what I have done my phone stoped making calls
Update (06/12/2018)
I restarted my phone then when I'm making call it deny
这个答案有帮助吗?
得分 1
添加一条评论
Method 1: Blocking Phone notification using third party app
Before you do this, check if your Android device has a built-in feature to disable notifications. This feature may be available in Android 5.0 Lollipop and Android 6.0 Marshmallow operating systems, but some systems may not give access to the “phone” app. Go to settings >> sounds and notifications >> Apps >> Scroll down and tap on “Phone” and disable notification. If your phone doesn’t have that feature, it’s time to give some third party apps a try.
If you Android phone is rooted, there is a fix. You can download apps that can block “Restricted access changed” notification.
Download Notification blocker app like this one: Notify Block
Open the app >> You will be asked to grant notification access >> Tap “OK”
Now on the app uncheck “Hide System Apps”
Scroll down and tap on “Phone” (com.android.phone)
Now reboot device and see if the error still persists. Within the notify blocker app, you may find several “Phone” icons. If the above steps didn’t work, try disabling notifications for each of the “Phone” icons on the list.
这个答案有帮助吗?
得分 0
1条评论:
can you send me logo of apps
完成的
添加一条评论
Method 2: For rooted Devices: Install Notification cleaner app
For this you will need to root your Android and also install Xposed framework. Most rooters will know how to do this.
Install Notify Clean and open it
Scroll down and tap “Phone”
Tap on “Restricted access changed”
Now reboot device and the phone notification will be blocked
Did any of the above method fix this notification error on your Android phone? Do you have any other alternative methods or solution? Drop a comment below.
这个答案有帮助吗?
得分 0
添加一条评论
Blocking the "Notification" is not the solution at all. It's just like ignoring the problem.
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue, and i went to network setting, start searching for network manually after the phone detected the network i selected it and its started connecting i removed the sim card and putted it back in less than a second and i got my phone back to business
Moto z play droid
This is a video i made because i know its a hard time
https://youtu.be/UUL4OJpmkz4
Hello from Dominican republic
这个答案有帮助吗?
得分 0
添加一条评论
i found a tutorial on this issue check it here https://alltechguru.net/android-restrict...
这个答案有帮助吗?
得分 0
添加一条评论
I just went to settings>SIM manager and there i disabled the SIM and again i enabled it...Then the problem was fixed but after few hours the same problem repeated again... Please help me!
这个答案有帮助吗?
得分 0
添加一条评论
Update (01/02/2019)
Sim card is not from Verizon Wireless
这个答案有帮助吗?
得分 0
添加一条评论
how r u I'm fine then
kyou
这个答案有帮助吗?
得分 0
添加一条评论
Body must be at least 20 characters, you entered 11
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larry Quay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 41,519
