跳转到主内容
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 个问题 查看全部
Power Jack connection is Damaged. Can this be replaced and fixed?
My mom's Asus Chromebook C201P has a damage power jack after it fell. The power cord will no longer plug in and so it can not be charged. I found the replacement part on Amazon for $10 but curious to know how complicated this is to replace? Do you happen to have a step by step on how to get to it and what it entails?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
CarolineM , The link below is a partial tear down to get inside the device to access the charge port. Repairing a loose USB type charge port that is soldered to the mother board is a delicate procedure and when not experienced while fixing could cause more damage to surrounding circuitry because of heat necessary to install new port or to reattach old port. Changing charge port,normally not a job for the beginner. 2nd link below is a video just to show what is involved in replacing, The guy makes it look easy but believe me it is not that easy and if going to attempt work very carefully and do not rush. If not comfortable doing repair have a good local computer repair shop have a look and estimate cost of repair. Good luck.
Asus Chromebook C201 Motherboard Replacement
https://www.youtube.com/watch?v=mXsw03qk...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
CarolineM 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,272
