跳转到主内容
加入维修社区 - 创建账户
Tickle Me Elmo 是 Tyco-Preschool 出品的一款儿童玩具,以儿童电视节目《芝麻街》中的角色 Elmo 为原型。它于 1996 年在美国首次推出。
How to rewire it up
Stop working and I need to rewire it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
It's a pity the manufacturer does not provide a repair kit and wiring diagrams.
完成的
Yellow, wire came loose.
完成的
添加一条评论
2个答案
最有帮助的答案
It ain't easy, but here's how to gut him:
http://makezine.com/2016/04/08/tickle-me...
这个答案有帮助吗?
得分 4
添加一条评论
Sometimes there is just a broken wire in the box due to the vibrations made by the oscillator and or the batteries being removed and replaced activity. A blown circuit is rare unless someone tried to fix it and wired it wrong. It only takes a millisecond to blow a component if wired wrong. Same holds if a circuit gets wet ! Best advice is to remove the power source i.e. the batteries; and dry everything before turning it on !
The circuit itself is a small card. There are a few discrete components that are wired to the card. Check the connections. If you don't know exactly where the broken wire goes, don't guess ! It could be the end of Elmo as you knew him ! Get advice ! It could be the difference of a quick soldering and having to replace the entire unit. Don't be afraid of opening it up while just checking. Just put the screws back the way they came out.
Do it all with the batteries removed, please !
If the Device does nothing, it maybe the on/off switch. The batteries are obviously the first thing you checked, right?
If it talks; but, doesn't wiggle, its the oscillator connection.
If it wiggles but doesn't talk, it may just be the speaker wire.
If it talked but didn't wiggle and someone worked on it and now it does nothing, the person blew a component on the board. Most likely a capacitor. They don't take change in polarity very well ! The whole board is as cheap as the sum of its parts and labor.
Good Luck !
这个答案有帮助吗?
得分 1
1条评论:
I need the wiring diagram I have a broken wire
完成的
添加一条评论
添加你的答案
Jemel Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 43
总计 5,768
