跳转到主内容
加入维修社区 - 创建账户
发布于 2015 年,型号:POLSP01W
Red light is blinking
My Polaroid SNAP wont print out pictures. The 3rd red light is blinking. Do I need a SD card that way it can work? Someone please answer ASAP.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
3条评论
I have this problem too, how did you solve it?
由完成的
i also have this problem. how am i supposed to take pictures?
由完成的
Me too ,how do you fix it?
由完成的
添加一条评论
4个答案
最有帮助的答案
@anonymous__ ,Anonymous, Find below links to troubleshoot your Polaroid SNAP, If the camera is still under warranty and problem persist after using the trouble shooting guide link #1 and your manual link#2, then use link #3 for contacting Polaroid support and warranty. Good luck.
Polaroid SNAP Troubleshooting
https://www.polaroidsnapcamera.com/skin/...
https://www.polaroidsnapcamera.com/snapc...
这个答案有帮助吗?
得分 2
添加一条评论
No you do not need an SD card to take pictures. You can either have the film OR the SD card. Or both! The red light is just telling you its missing whatever the red light is flashing in.
这个答案有帮助吗?
得分 0
添加一条评论
I think I know how to fix the problem. The camera is very picky depending on how you put the film in make sure the part that says sink zero ink is facing downwards and the blank part should be facing towards you.
这个答案有帮助吗?
得分 0
添加一条评论
I had this same problem. It was an error with the paper, I had to keep playing with it a little. I bent the stack of paper a little the other way to straighten it out as it was bent just slightly and then i pressed hard on the back when I closed it. I think that helped get the paper in place…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anonymous 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 46
总计 31,793
