跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Laptop will not charge?
So I bought a MacBook air from someone with intent on fixing it. I get home to charge it and it doesn't( that i knew already) so i started trouble shooting and i figured that it was the battery so i bought replacement and that didn't solve the problem! I can get it to charge but only if I unplug the battery and plug up the ac adapter wait for the computer to start booting and then plug up the battery!? and this method works on both batteries old and new. What is the issue I've never seen this before?!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What light is the charger when the battery is connected, dim green?
完成的
I can only get a light while the battery is unplugged; its a bright green and then it turns orange after i plug up the battery. i can't get a charge light no other way
完成的
That's strange. Check the whole board for liquid damage and check the charging IC for any burnt pins too. It is able to communicate with the battery clearly, so its a bit of a weird one.
完成的
Thank you I'll give that a try! My Coworker is selling me her 2014 air for cheep because of water damage so I'll salvage those parts and hopefully the I/O board is good and I'll swap those to see if thats the issue! I really appreciate your help!
完成的
添加一条评论
2个答案
已选择的解决方案
I had this model in yesterday with the same issue. I replace the I/O board and fixed it: MacBook Air 13" Mid 2012 I/O Board Replacement
MacBook Air 13" (Mid 2012) I/O Board
Replace an I/O board compatible with the Mid 2012 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.图片
产品
$89.99
这个答案有帮助吗?
得分 2
1条评论:
I have had my macbook air’s left i/o board and flex cable replaced after spilling milk tea on it but after the replacement the battery won’t charge after a while?
完成的
添加一条评论
Try to reset the SMC and PRAM
这个答案有帮助吗?
得分 1
2条评论:
Sweet I'll give that a try! Thank you!
完成的
Still no dice?! So weird maybe the I/O board?
完成的
添加一条评论
添加你的答案
Ray McGee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 130
