跳转到主内容
Check out these guides for information on repairing and dissembling your sewing machine.
Skips threading in between sewing.
Hey everyone!
So heres a good question. Does anyone know why a commercial grade juki sewing machine would be skipping stitches while sewing? I work at a location where this happens a lot and we have to outsource the labor for repairs. However it would be beneficial for the company to have someone there to fix this issue. Please let me know as far as what could be the issue and maybe how to go about this maybe? I do appreciate all of you guys and thank you for your help!
-Daveyloder
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could be any of a number of issues:
  • thread/needle incompatibility
  • incorrect top/bottom thread tensions
  • blunt, worn or damaged hook
  • timing slightly out
* etc.
You will need to work through all possibilities, one by one, and, if still a problem then ask a Juki engineer to look at it,
这个答案有帮助吗?
得分 0
1条评论:
If it is used commercially, then it will accumulate a lot of debris quickly. That can prevent the rotating thread pickup under the plate from grabbing the thread and a missed stich occurs. On the other hand, your outsourced labor needs to eat also, so why deprive them?
完成的
添加一条评论
添加你的答案
David Loder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 100
