跳转到主内容
加入维修社区 - 创建账户
1.5 GHz Core Solo、1.66 或 1.83 GHz Core Duo,或 1.83 或 2 GHz Core 2 Duo 处理器。 本页面涵盖了从 2006 年初到 2007 年中的首批基于 Intel 处理器的 Mac mini 机型。
Anyone found an alternative Mac Mini outer casing?
Hi! I recently acquired a 100% functional Mac Mini from a recycler, the only catch being that the outer casing has been destroyed, and so the guts of the Mini are exposed, and it's not really in re-saleable condition. I've looked into replacing the casing, but it seems a little silly to spend $50-$100 that people are asking.
Does anyone have thoughts on a practical alternative to Apple's Mini case? I'd prefer something on the practical/discreet side, as opposed to goofy and outrageous.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
If you end up with it in the cube case or the floppy disk drive, you should take some pics and link them here so we can take a look at what you did.
由完成的
添加一条评论
4个答案
已选择的解决方案
How about a nice ammo box. Lay it on its side, cut the top for the CD drive. Larger boxes could be used for extra hard drives. Comes with a carrying handle.
http://www.amazon.com/Military-Ammo-Wate...
For a bigger box, use the 50 cal version: http://www.amazon.com/Military-Surplus-C...
Here's a bunch of various goodies: http://www.colemans.com/ammocan.htm
Consider using the dome from a iMac G4 with out the screen attached.
这个答案有帮助吗?
得分 3
6条评论:
Or an old mac cube case would be awesome! but the little research I did I couldn't really find one for much less than $50.
由完成的
Awesome idea Mayer! I'm going to seriously consider it...my only concern is that the metal might keep wireless from working, but I'm sure there are ways around that.
R Trent, thanks for the idea...I have an old Cube around, so I'll see if it fits...that would potentially be a fairly easy solution.
由完成的
good answer +
由完成的
Yeah WL might be an issue- also it'd add a TON of weight, probably not good for ventilation either though, do you have a CNC machine?
由完成的
The cube's a great idea- in fact, it's upgrading the Cube so you get some sort of Mac Cube? Cube Mini? Whose origins cross processors and years.
由完成的
显示更多的1条评论
添加一条评论
Here is one that mayer came up with on Meta that I really like.
http://www.pcworld.com/article/170973/co...
这个答案有帮助吗?
得分 3
3条评论:
Oh wow, that is amazing!!! I just finished putting it into a Cube case, but I think I'm going to buy an Apple floppy drive on eBay now, cuz that's just too cool to not try! :-) Thanks!
由完成的
legitt +
由完成的
+ I forgot about that one. It's good.
由完成的
添加一条评论
How about buying a cheap generic mini-pc case? You can also often get those with a built in power supply, which is useful.
这个答案有帮助吗?
得分 1
3条评论:
For example, a quick eBay search turned this up, I'm sure you could get much cheaper with more thorough searching, and for Used as opposed to New parts
由完成的
Great idea Rab! I'll take a look.
由完成的
添加一条评论
Duct Tape
这个答案有帮助吗?
得分 1
1条评论:
I like the idea, but wouldn't that run the risk of making the computer overheat?
由完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 33
总计 4,829
