跳转到主内容
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
28 个问题 查看全部
Can Toyota Diagnose Transmission error Code P 2757 without tear down?
I have a 2010 Toyota Corolla LE 70,000 miles.... Can the Toyota dealership, or Transmission shop diagnose the actual problem with error code P2757 related to the Torque Converter Clutch Pressure Control Solenoid Circuit Performance Stuck off reading. The dealership said they needed to tear the transmission apart to find problem. I do not believe them. I have been told by other mechanics that their computer testing equipment should be able to detect which solenoid is out. can a single solenoid be replaced if it can be detected? Please help and advise.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
I can say with 100% confidence this problem can be diagnosed without transmission removal and teardown! The answer to your question__can a single solenoid be replaced?__YES! I am not sure if I am allowed to give my name and phone number on here so I will check back for a reply to my comment.
Good Luck,
Buck & Dennis
完成的
I have the same problem with my 2010 toyota voxy....... i would love to get it fixed
完成的
添加一条评论
7个答案
已选择的解决方案
@michaelangelo nobody on here can answer this question with any kind of certainty. This will totally depend on the dealers capabilities. My suggestion is that you find a different dealer. You stated that you "do not believe them" so go somewhere else for a second or third opinion.
这个答案有帮助吗?
得分 4
3条评论:
Thank you for addressing the question, but I would like to know if anybody has fixed or dealt with the error code P2757 for Toyota Corolla 2010. what is the process for identifying which solenoid valve is possibly bad, or the wiring, or harness, etc. does it really require an expensive tear down to determine any of the above?
完成的
If you do an extensive search you will find there are plenty of bad stories about this. I'd stick with having a dealership at least taking a look at it. Check this out "P2757 TCC stuck on is a mechanical problem w/ the torque convertor clutch system. Mechanical meaning the torque convertor, SLU solenoid, any of the TCC or pressure regulator valves inside of the valve body or a poor circulating transmission cooler system will. Any of these issues will trip this code. If you want it fixed then take it to a competent A/T technician. " from here
完成的
I have a Lexus IS250 2007 with this error code. With mine its the sixth speed solenoid thats faulty because when I drive it as a manual and don't select 6th gear then I wont get the error code.
完成的
添加一条评论
最有帮助的答案
@michaelangelo , Michael, If vehicle out of warranty, skip the dealership and find a good local professional transmission repair shop, as they are probably more familiar fixing this problem then some of dealerships. In a lot of cases the dealer ship actually does not fix the transmissions in house, all they do is remove and send out for repair and then reinstall after transmission shop did repair. Have a good transmission shop take a look, diagnose and estimate repair. Good luck.
这个答案有帮助吗?
得分 5
添加一条评论
Sir base on my experience as toyota technician i agree to teardown your transmision.we have same cases here after we open the rear side of transmision cover we have found that overdrive clutch and plates is burned out and even we replace the said shift solenoid valve and worn out disc and plates but still you cam feel the sudden shiftshock.so we decided to make overhaul ..
这个答案有帮助吗?
得分 1
添加一条评论
No post since 2016. Waste of time to say it is solved. If this is solved then so is The Middle Eastern Crisis!!!!
这个答案有帮助吗?
得分 0
添加一条评论
have a 2006 lexus GS300 same F problem…replaced solenoid , did nothing…lexus sucks
这个答案有帮助吗?
得分 0
添加一条评论
I have a 2007 IS250 and it will come up with this fault. I just keep resetting it. But I notice that if I drive it in Sports mode and don’t use 6th speed it never faults.
这个答案有帮助吗?
得分 0
添加一条评论
Check ur fluid for &&^& sake!!!
这个答案有帮助吗?
得分 0
2条评论:
They are a sealed for life unit. You don't change the fluid and they don't leak.
完成的
Sealed huh, these trannys. have a removable pan and bolts. Change your fluid an filter every 30 - 40 thousand miles and you will have a trans. that will probably last forever. In other words a long, long time. Toyota builds very very good transmissions.
完成的
添加一条评论
添加你的答案
Michael Angelo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 76
总计 22,497
