Can Toyota Diagnose Transmission error Code P 2757 without tear down?
I have a 2010 Toyota Corolla LE 70,000 miles.... Can the Toyota dealership, or Transmission shop diagnose the actual problem with error code P2757 related to the Torque Converter Clutch Pressure Control Solenoid Circuit Performance Stuck off reading. The dealership said they needed to tear the transmission apart to find problem. I do not believe them. I have been told by other mechanics that their computer testing equipment should be able to detect which solenoid is out. can a single solenoid be replaced if it can be detected? Please help and advise.
2条评论
I can say with 100% confidence this problem can be diagnosed without transmission removal and teardown! The answer to your question__can a single solenoid be replaced?__YES! I am not sure if I am allowed to give my name and phone number on here so I will check back for a reply to my comment.
Good Luck,
Buck & Dennis
由 Dennis Noriega 完成的
I have the same problem with my 2010 toyota voxy....... i would love to get it fixed
由 carlos clarke 完成的
