跳转到主内容
The Sony Cyber-shot DSC-HX9V is a compact digital camera with a 16.2 megapixel resolution. The dimensions are 4.1"x2.3"x1.3" (WxHxD).
11 个问题 查看全部
Why is my SD card not inserting?
SD card on Sony Cyber-Shot DSC HX9V will not fully insert into the SD card slot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
sony cyber shot dsc-w800 memory card not working in the camera slot when turned on! no image on the screen until I remove the sd card / the card was formatted in the camera ok!
完成的
添加一条评论
1个答案
已选择的解决方案
Hey there Deepjot! Sorry to hear that you are running into this issue. One possible issue you could be having is there is debris stuck in the SD slot. If this is the case use a hairpin and attempt to dislodge the debris from the slot.
For more troubleshooting visit this page:
Sony Cyber-shot DSC-HX9V Troubleshooting
这个答案有帮助吗?
得分 2
1条评论:
Is there any other solution to this problem. II can not get my card to lock in when I insert it?
完成的
添加一条评论
添加你的答案
Deepjot 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 1,263
