Why is my SD card not inserting?
SD card on Sony Cyber-Shot DSC HX9V will not fully insert into the SD card slot.
Hey there Deepjot! Sorry to hear that you are running into this issue. One possible issue you could be having is there is debris stuck in the SD slot. If this is the case use a hairpin and attempt to dislodge the debris from the slot.
For more troubleshooting visit this page:
这个答案有帮助吗?
Is there any other solution to this problem. II can not get my card to lock in when I insert it?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,508
1条评论
sony cyber shot dsc-w800 memory card not working in the camera slot when turned on! no image on the screen until I remove the sd card / the card was formatted in the camera ok!
由 James Dale 完成的
