跳转到主内容
加入维修社区 - 创建账户
Behringer Eurolive B212D 扬声器系统的设备与维修信息。
Power on and off
Behringer Eurolive B212D power on and off.
When I turn the switch on, it stays on for a couple of seconds, and then turns off by itself. I then have to turn it off, and turn it back on. It will stay on for a few seconds & then turn off again, on its own. What could be the cause? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
marekman101 could be bad capacitors or MOSFET on the power board. You'll have to disassemble it and take a look at the board for obvious failed components like domed or leaking caps. Check these guides to help you. Post some images of what you find with your question so we can see what you see. Use this guide for that.
这个答案有帮助吗?
得分 1
2条评论:
I have a Behringer 550 w ro live speaker that won't come on when you hit the on and off button. Sometimes I can do it 8 or 10 times and it might come on so I just duct tape the button to stay on and when I want to cut the speaker off I disconnect the power supply cord. Does anyone know if this is just a on and off switch problem?
由完成的
@richardtstokes if this "I just duct tape the button to stay on" works all the time, then yes, the issue will be the power switch.
由完成的
添加一条评论
添加你的答案
marekman101 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 3,389
