跳转到主内容
加入维修社区 - 创建账户
JBL Clip+ 是一款由 JBL 公司于 2015 年推出的便携式蓝牙音箱。它是基于前一代 JBL Clip 设计的第二款机型。
My micro usb Detached
I dont have how to charge my Speaker, my micro usb is detached and in service all says the same: It cant be repaired. Can i charge my battery with other method? I want to cut battery wires and add usb port to charge it with phone charger.
Update (10/30/2016)
Here re some photos, What photos need more i can do better, more precis. Rip my English, Im from Poland.
Update (10/30/2016)
Here are better photos of this under part of the speaker
Update (10/30/2016)
here are more photos from close
Update (11/01/2016)
This is my idea, but i have question, if i charge my battery with this method, and let it for night(example) battery wouldnt take fire or something? This usb connection will not be in speaker because there is not enought space, I want the speaker to work, not to show good, but if it is a method to work with good look so i take this with good look, but if no i will do my idea, What do you think @oldturkey03
Update (11/04/2016)
Here are better photos, I think are better and you can better see and help me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
26条评论
@norbi does the second last image show where the connector used to be? Your English is fine, probably better than our Polish:-)
由完成的
The last image shows where the micro usb was, this little lines on bottom. The second last shows 3 Wires, Red, Black and blue, Getting out from battery, and the Black that is at left shows Mini Jack. I dont know nothing about electricity, i know only get together wires, to solder it.
由完成的
if you can post me this picture or something, i can do new more precisy to show all of the components.
由完成的
@norbi yep got it now. Is there any chance you can zoom in with your camera? when I enlarge the picture it becomes to unclear. It looks like there are traces that are visible....
由完成的
显示更多的21条评论
添加一条评论
2个答案
已选择的解决方案
@norbi not a good idea just connecting it to the battery. You are bypassing the whole charging circuitry which controls rate of charge/ over charging etc. I would connect it to where the old port is. Post some imgaes that show the whole PCB and the micro USB port.
Update (11/04/2016)
I'd connect the positive to where the positive from your connector was.
这个答案有帮助吗?
得分 3
6条评论:
why you dont answer ?
由完成的
@norbi sorry but was busy last couple of days and only briefly paid ifixit a visit. I attached an image where I would connect the positive wire to. The negative should be okay to connect to the battery wire.
由完成的
Could you send me image when to connect the second wire? i will be very happy :) because battery has 3 wires.
由完成的
Thank you SO MUCH You are the best Bro! I found the negative it was black. SPeaker is charging Thank you again!
由完成的
显示更多的1条评论
添加一条评论
Hello Can I charge the battery? can you post a picture of the arrangement please?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
norbitron1234 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 3,138
