跳转到主内容
The Nokia N900 is a mobile Internet device and smartphone from Nokia that supersedes the N810.
5 个问题 查看全部
Need motherboard for nokia n900
Need an upgrade for motherboard, is it possible?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Nivetha, Check the attached links for replace Nokia N900 replacement mother board or google search for more availability on part. Good luck.
https://www.aliexpress.com/price/nokia-n...
Nokia N900 Teardown
这个答案有帮助吗?
得分 1
2条评论:
Is it possible for replacing motherboard with someother mobiles version?
Like installing android for instance?
完成的
Nivetha, There is new concept replacement board in the works, they call it Neo900, Although it is not available yet, check attached link.
https://www.youtube.com/watch?v=EJHMXQ3n...
完成的
添加一条评论
@nezni9 no it is not. Your phone will only accept the motherboard it currently has due to the layout. The connectors, buttons, etc. are all depending on this type of board. You can only replace the same board. If you want a different OS or other different features, you will need a different phone.
这个答案有帮助吗?
得分 1
2条评论:
I know that. I have other phones. But I was just wondering if it's possible to upgrade this phone. I love this phone. My first ever phone.
完成的
@nezni9 the only upgrade it would allow you to do is the firmware update. Anything else, like the Neo900, is based on plenty of hard and software hacks that have not (and may never be) implemented.
完成的
添加一条评论
添加你的答案
Nivetha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 663
