跳转到主内容
Repair guides and support for a wide range of mattresses.
6 个问题 查看全部
making the foam mattress pad fit the queen size mattress
I currently have a regular queen sized mattress but its firm but it was new and free. it is also uncomfortable, so I purchased one of those foam mattress toppers to put on top of the mattress. Now I sleep better but the problem is even though the topper is supposed to be queen sized ...it slips and slides and doesn't meet all four corners of my existing mattress. Which mean every morning I must pull or tug it back to the other side. How or what can I do to prevent this from happening?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Get yourself a set of sheet straps, $5:
https://www.bedbathandbeyond.com/store/p...
这个答案有帮助吗?
得分 1
添加一条评论
cassandra, Bare mattress material pretty slippery, try putting a fitted cotton sheet on the bare mattress, then the mattress topper, then another fitted sheet, holds pretty good. Other methods are carpet tape(2 sided tape), sheet garter(corner-elastics at the dollar store), anti slip mats for under carpet or as drawer liners also found dollar store,hardware stores,etc. cut a couple into wide strips and place between pad and mattress at corners and middle perimeter.
这个答案有帮助吗?
得分 1
添加一条评论
@decodiva67 really not much you can do about it. If it is really bothersome I'd go with some wide industrial strength Velcro between the topper and the mattress.
这个答案有帮助吗?
得分 0
添加一条评论
Choosing a new mattress is a difficult task. There are hundreds of facts that you have to consider when buying a mattress. Few of them are firmness level of the mattress, comfort, back support and body contour, no pressure creation on your body, motion separation, edge support, sinking & sagging, etc. If you consider these facts you may get a good comfortable mattress. You can learn more about mattress problems reading these articles below.
https://www.mattressinsight.com/soft-mat...
https://www.youtube.com/watch?v=nDZrmt8B...
https://www.mattressinsight.com/new-matt...
https://www.quora.com/Firm-mattresses-gi...
https://www.mattressinsight.com/mattress...
https://www.mattressinsight.com/can-bad-...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cassandra baker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 67
总计 10,610
