跳转到主内容
加入维修社区 - 创建账户
2007 年 10 月发布的无线路由器,型号为 WGR614v9。
Removing repeater function when reset button is not working
Hi,
I've a Netgear WGR614v9 which I tried using as a repeater and thus set it up with another router. But it did not work. I want to reset the router now, but it does not provide any IP to my computer even when the main router is switched off. The reset button malfunctioned few months back and its not working.
Can you please let me know how to reset the netgear WGR 614v9 manually without reset button?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi, Have you tried logging into the router by directly connecting an Ethernet cable from the router to the PC, opening a browser page and typing 192.168.1.1 in the address bar?
由完成的 分享
Hi Jayeff,
Yes, I've tried logging into the router by directly connecting an Ethernet cable from the router to the PC, but this is not working as DHCP has been disabled due to repeater function requirements and thus, no IP is assigned to PC.
I'll try opening the router today and then resetting it through its circuits near the Reset Button. Hopefully, this may work.
Thanks,
Parminder
由完成的 分享
how did you solve this problem? i am stuck on the same thing.. and not getting any help anywhere
由完成的 分享
Prateek, you need to start your own question, this is 2 years old...
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
How do I perform a factory reset on my NETGEAR router?
  1. On the back of your router, locate the Restore Factory Settings or Resetbutton.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
这个答案有帮助吗?
得分 2
添加一条评论
Try 30.30.30 reset.
Hold the reset button for 30 sec. while plugged in. Then while still holding the reset button , unplug the power cord from the router for an additional 30 sec., then still holding the button, plug the power cord for the last 30 sec., and release it. Everything should reset to the default settings.
Let me know if it worked.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Parminder Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 5,685
