跳转到主内容
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
20 个问题 查看全部
We need help fixing this thing we've tryed everything
We spilled a small amount of liquid on the touchpad then his computer shut down and he says "it went all staticky for a moment" and when we tried turning it on it showed a black screen (it was on it glowed a little) we tried to take off the bottom but we can't get it off. And by we I mean me and my brother so please help us my brother will be devistated if we can't fix this
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here's are the guides that will show you how to get into ti:
HP Flyer Red
How to clean it after you get into it:
Electronics Water Damage
这个答案有帮助吗?
得分 2
5条评论:
To add to Mayer's answer, (Thanks Richard) here is a link to the Service Manual. On p.17 it gives the part number (s) for the Touchpad and on p.49 it details the removal procedure. I also suggest that you gently clean any liquid affected area with Isopropyl Alcohol 90%+ to remove any possibility of corrosion.
http://h10032.www1.hp.com/ctg/Manual/c04...
完成的
But it seeped in its been an hour or 2 since this happened
完成的
Hi, Remove the battery. Then you'll have to open the notebook furtherand gently clean the affected area put it back together and try it. If it still fails you may have to replace the touchpad assembly.
here is a link that generally explains what you have to do with water problems and electronics
If it seems like too much for you, take it to a reputable computer repair service to get it professionally repaired. The sooner the better.
完成的
Thanks we will try both of those! Edit: one of the screws won't come out we've tried of lot shakes too so we might have to get someone else to do it but how mutch does it cost?
完成的
Try phoning a few repair services and asking for a 'ballpark' estimate of the cost . They won't know the exact cost until they see what is needed to be done, but perhaps you'll get some idea
完成的
添加一条评论
添加你的答案
Zomby 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 150
