ignition switch wiring diagram color codes
what are the wiring color codes of ignition switch
Peter, You can find your wiring schematics at the sight attached and download free.
这个答案有帮助吗?
Peter Celdran, not quite sure what you are looking for but start with this
You definitely have 3B- Yellow, 2B- White and 2L-Black. If you post some images of what you are looking at, we might narrow it down. Use this guide for that.
这个答案有帮助吗?
this is the harness I just need to know which one is the battery wires and which one is the ignition wires
这个答案有帮助吗?
@bonnie88229 looks like Black/Yellow and Black/White for the ignition. White should be battery but we need to know the exact year, model and engine size to make sure. Use a test light or meter on each wire. You should be able to get the battery + which should have power at all times.
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 95
总计 11,265
